1. BoshWadeJames's Avatar
    Okay, I've recently rooted my phone, really not having any idea what I was doing. I just wanted cm7 with android 2.3 and I messed up my phone. I cant do anything to it. I have no back up so I'm stuck in Android System Recovery. Everything I try does not work, I don't know how to flash anything or get into adb. I really need some help, can someone please help me?
    06-19-2011 04:51 AM
  2. joshlete's Avatar
    The first thing is that your going to have to figure out how to get abd or something. If/once you figure that out, find a way to install this:
    http://forum.androidcentral.com/lg-o...-2518-6-a.html
    Once you install that custom recovery, you should get it fixed. Though I am not sure how to help you on getting abd.
    06-19-2011 05:05 AM
