optimus v reborn rom boot loop. Help!
Jerenater10
Active member
May 4, 2011
27
My Optimus V has REBORN ROM flashed on it. a few weeks ago i flashed a theme for Reborn by the Theme_Team. it was working fine but i decided to install GO Launcher EX. i really liked it but the colors of the theme i had didn't go with the launcher. so i installed the stock reborn rom theme to my phone. i just flashed it about 10 minutes a go and rebooted. Reborn ROM's boot animation is a circle that says reborn rom that zooms up into the center of the display. after i rebooted, the logo starts to zoom up but then it stops, resets and then trys to zoom up again in an endless loop. im not sure if i should remove the battery or not. Please Help!
rockneo
182
9
Remove the battery it wont mess anything up and try again if that doesn't work restore your nandroid hopefully.you made one otherwise you'll have to reflash the rom
Sent from my Optimus V
Jerenater10
Active member
May 4, 2011
27
took the battery out but the problem was still their. backup i made couldnt be found. just reflashed the ROM everythings good i used TI to make a backup of all my apps.
Cy3berOdyssey
