1. AC Question's Avatar
    The unit is a Eonon GA5163F for a 2011 Mazda 3.
    What Gz size card do I need.Australia wide ? and S.Australia.
    Thanks
    04-26-2016 05:53 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Moved to the Android Auto forum.
    Can you clarify the problem? Are you saying that you have an Android Auto head unit that has no operating system installed?
    04-26-2016 01:23 PM
  3. Victor Howard's Avatar
    You have a head unit that runs Android as an OS. There's nothing to say it's built for Android Auto, which sources through a phone. This is a standalone unit that you can load Google Maps onto. You'd have to get a GPS antenna and hook it up, or figure some way to do it through your USB connected phone.
    I mean, this is an old unit. It's running 4.4.4. the current build of Android is 6.0.1.
    B. Diddy likes this.
    04-28-2016 02:51 PM
  4. B. Diddy's Avatar
    Very good point--I should've caught that! I'll move this to the Other In-Car Systems forum instead.
    04-29-2016 01:14 AM
  1. Replies: 3
    Last Post: 08-29-2017, 08:26 AM
  2. Replies: 3
    Last Post: 04-28-2016, 02:04 PM
  3. Replies: 1
    Last Post: 04-26-2016, 01:26 PM
  4. Can I get my data back after my tablet was set to manufacture's setting?
    Last Post: 04-26-2016, 01:25 PM
  5. Replies: 1
    Last Post: 04-26-2016, 06:44 AM
