Hizpo head unit with inverted screen
Hello everyone. I’ve got a hizpo radio head unit running Android 7.1.2 with an inverted screen. What can I do to fix this problem? Any help would be greatly appreciated as I’m new to Android and would like to get this in my car finally. A friend of mine give it to me a few weeks back.
1 Attachment(s)
Re: Hizpo head unit with inverted screen
Here’s a pic of the radio.
Welcome to Android Central! See if you can go to Settings>About Device and tap Build Number 7 times to activate Developer Options. Then go back to the main system settings to open the Developer Options. See if there's an option there to show a reversed image. I know there's an option for "Force RTL" (which means Right to Left), but this shouldn't cause things to be mirror image -- it should just show the test reading from right to left.
Originally Posted by
B. Diddy Welcome to Android Central! See if you can go to Settings>About Device and tap Build Number 7 times to activate Developer Options. Then go back to the main system settings to open the Developer Options. See if there's an option there to show a reversed image. I know there's an option for "Force RTL" (which means Right to Left), but this shouldn't cause things to be mirror image -- it should just show the test reading from right to left.
Thank you for your help.
It won’t give me the developer options after pressing build version 7 times for some reason.
That was a longshot anyway. My suspicion is that it's a problem with the hardware or firmware. It'd be ideal if you could contact the manufacturer for support, but I can't find anything online for that. There is a website for an online Hizpo store, but there's no Support section. Did it come with a manual or any paperwork?
I’ve got the manual to it and a quick setup guide it has a troubleshooting section but nothing about that. No support number or anything listed.
can you install regular android operating system and firmware on these?
Hello were you able to solve the problem you had with your hizpo android stereo ? If yes how was it done. I need some help please
amo16 Hello were you able to solve the problem you had with your hizpo android stereo ? If yes how was it done. I need some help please
If you are having a similar issue with an Android radio, it's unlikely you can get it fixed. They are sold by fly by night companies with zero customer support, and made of cheap components of questionable quality. No one recommends these units because they are junk, so you may just have to cut your losses and get a name brand radio.
