1. 1magus's Avatar
    So I have had this problem for quite some time now. If I connect a USB cable to my Xperia Play Atat phone ( runs Android 3.2.3 ) it will eventually freeze, wont connect to my windows PC and reboots the phone!
    I have tried resetting my settings to see if that helps, tried turning off the Sony Ericsson software on my PC but it always ends the same!
    11-16-2011 11:40 PM
