1. justacrazymom's Avatar
    I tried to update my Xperia 10 and now it will not boot.. all i get is the Sony Ericsson flash across the screen then an image with a triangle with a ! in it and a flat pictures of a phone.. help!
    04-02-2012 01:11 PM
  2. iOS Gravity's Avatar
    If you rooted it, then that's probably why it happened. Should have unrooted then updated. On the other hand you should call your carrier about this if you didn't root it.
    04-11-2013 06:36 PM
