1. Lee Tollerfield's Avatar
    I have a Sony Xperia S
    My Network is 02-UK
    I have a Voicemail notification in the top left corner of my screen!
    When I slide down at the top to show notifications, the Voicemail notification is there and even if I press 'Clear,' the notification stays!
    Underneath it says 'Dial 1235' because that is the number I set for Voicemail on my phone because my phone never had one...
    When I either press the notification it rings '1235' or if I manually ring '1235' it either tells me that this is an unknown number or it does this 'Speaking Clock' thing.. It says: "At the 3rd stroke, the time bought to you by 02 will be [specific time (hh:mm:ss)]
    This is very frustrating, as this is a new phone and I have already had to replace the model once!
    Thanks for your help.
    04-09-2012 03:36 PM
  2. strongful's Avatar
    901 that should be your vm number I think?
    Sufficient unto the day is the evil thereof.
    07-14-2012 01:54 PM
