1. Travis Gearhart's Avatar
    Alright,
    so i have a Sony Xperia Ion from AT&T and i found this picture and want to make my phone look like it too (included in link)
    Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
    I found the background live wallpaper (its called Air stream live wallpaper) but i want the weather widget, clock and date widget and the bottom bar i cannot find any information!!!!
    Thanks for the help!!!
    Travis
    04-21-2013 09:23 PM
  2. stalemate1's Avatar
    All I can recommend is to try find the contact details of the website where you found this and ask them.
    04-22-2013 02:18 AM
  3. stalemate1's Avatar
    Alright,
    Travis
    Try Atom widget with this theme:
    https://play.google.com/store/apps/d...odernTypoBlack
    Then adjust the display of the widgets and icons to you liking. I think this one is it, its the closest I've found to it.
    Just play around with this theme and launcher, see what you can customize, see what you cant and report back.
    04-23-2013 04:37 AM
  1. I need help...trying to find more GPS Voices
    By sportsjoe17 in forum Android Apps
    Last Post: 12-03-2012, 06:01 PM
  2. HELP! Can not find working MR2.5 radio dl link!
    By alpaqqa in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 10-05-2012, 08:33 PM
  3. NEED HELP. can't find anything
    By theman97 in forum HTC EVO 3D Rooting, ROMs, and Hacks
    Last Post: 07-20-2012, 08:15 PM
  4. Help trying to find this wallpaper...
    By Bean#AC in forum Wallpapers, Ringtones, and Themes
    Last Post: 03-10-2012, 12:39 AM
  5. help! i cant find my picture folder
    By anon58445 in forum Verizon Fascinate
    Last Post: 12-06-2010, 01:42 PM
