1. lastride25's Avatar
    I am trying to remove the at&t from my (new) Xperia X10. I have installed universal android, superuser.apk, Titanium Backup, and Android Mate. when I try to uninstall the bloatware, my phone says the uninstall was unsuccessful. I have read that I should go to settings--applications-- and click unknown apps...the problem is that I do not have that option. I figure I can't be the first to run into this problem.
    Help!!!
    10-28-2010 07:56 PM
  2. StanS's Avatar
    Even with Root on the phone, you can't uninstall these, you can only FREEZE them with the Titanium Backup.
    Your only hope to free the ROM is to update to a Generic 2.1 update (even now in Jan ATT has not released a 2.1 update) then you won't have any ATT stuff, and the SE apps like Moxier and Wisepilot can be uninstalled with anything if you have root.
    Be aware that SE is beginning to propagate firmware that can NOT be rooted by the current methods.
    01-05-2011 09:36 AM
