1. AC Question's Avatar
    I got this zte 755 cricket less tan a week ago. In just a few days it went through more than the 2.5GB allowed on my plan! What can i do to,delete, idle apps or what? This is my 1st smartphone and I know NOTHING! PLEASE HELP me!
    10-27-2015 12:20 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! To be clear--you're concerned about the data usage, not internal storage running low, correct? They're two different things.
    Go to Settings>Data Usage to see what apps are using the most data. For some apps, you can go to their menus and look for a Data Refresh or Sync option, and set it to Manual (or the longest interval possible). For apps that don't give you this option, you can select the app in the Data Usage menu and tap Restrict Background Data (or you can universally Restrict Background Data, but this might make you miss things like important app notifications).
    This guide might be generally useful for you: http://forums.androidcentral.com/gen...-lollipop.html
    10-27-2015 07:03 PM
  1. Nexus 6P vs. DROID TURBO 2
    By TrekkieMonster in forum Phone Wars
    Last Post: 12-20-2015, 12:48 AM
  2. Replies: 1
    Last Post: 10-27-2015, 07:16 PM
  3. Replies: 1
    Last Post: 10-27-2015, 07:12 PM
