1. OklahomaHoss's Avatar
    Just started this morning. Plugged it in to charger when I got in to work, and it stays on the charger all day, only off if I get up for a 15 minute break or a 30 minute lunch.
    Naturally batter is always showing full at 100% or close to that if near the end of lunch after watching Netflix during lunch.
    Today, it showed down to 65% after just having been unplugged from a 4 hour charge. It charged up to show 77% then the little lightning bolt on the batter disappeared and on the top left of the screen was the little "full battery" icon telling you the charge was full and to disconnect the charger. Four inches to the right on the top right of the screen, the battery shows 76%.
    I tried restarting the phone, but it's still the same.
    So is it fully charged as it should be? Or is the battery or the phone crapping out on me?
    08-17-2016 01:43 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try recalibrating the battery sensor software by charging up to 100% (if possible), then using the phone normally until it shuts down from low battery. Then charge up again to 100%. You might have to repeat this cycle a couple of times.
    08-18-2016 04:35 AM
  3. RedWingFan70's Avatar
    I have had this happen to me as well....I will try the suggestion given and see if that helps. Thanks for the input
    08-23-2016 09:19 AM
  4. RedWingFan70's Avatar
    Are you still having the battery percentage indication issue?
    09-12-2016 12:30 PM
  1. best value phone on Verizon?
    By Justin_1138 in forum Verizon
    Last Post: 09-25-2016, 03:00 PM
  2. Terrible battery drain and slight overheating...
    By zcherub in forum Samsung Galaxy Note 5
    Last Post: 08-26-2016, 11:29 PM
  3. Replies: 8
    Last Post: 08-26-2016, 05:40 PM
  4. Replies: 5
    Last Post: 08-17-2016, 10:54 PM
  5. Why does the Keybord keep popping up?
    Last Post: 08-17-2016, 01:14 PM
