Originally Posted by
AC Question my tab is not showing the return bar at the bottom of the screen (where all the four buttons shows - return, home , apps switch button), . So, i am unable to go back every time I have to switch off my tab. and keep showing that 'cps is not working'. and its automatically starts downloading useless apps and keep showing full screen ads on it. I am just totally tired of it. Pls, give some advice what to do.
Have you checked settings for an update? Do a factory reset if you don't have any updates. It sounds like you might have some malware installed.
Also, this post is in the wrong forum, but hope I helped!
