ordivergens
Got the Gold 64 GB Note 5 from tmo. It was even cheaper than I thought. It was only 670 (less than 32 gb models from other places). I will be keeping this one and sending the 6P back. I must be the only one, but I prefer TW to Stock.
To be honest, after using the Note 5 for a while now, stock Marshmallow seems a bit bare and minimalist. I really like the little extras Samsung has put in TW. I miss TW when I use the 6P... I wasn't expecting this. I thought I would dislike all the extra bloat, but I was basing that on the older TW versions from Gingerbread.
So I got a V10 to try as well
It is a solid phone, heavy (I like that), replaceable battery, ir blaster, micro sd card, and the camera is awesome. Not sure about the second screen yet. Unfortunately I dislike the UI from LG. Everything is ridiculously big and blown up on the screen. Not as elegant as TW. I will probably return this.
I am wondering if I should return my international N5 and get a tmo Note 5, that way I could get Wifi calling, VoLTE, Samsung Pay, etc.
Did tmo add a lot of their apps to the Note? Did they disable app optimization that Samsung recently added? How do you like it so far?
$670 is a great price for the 64GB N5, and it looks like we can get 1 year of Netflix as well from tmo. Tempted to get this tomorrow...
