1. strawhatnito0890's Avatar
    So I downloaded everything I needed and watched da videoion how to install cm9 ics on my fone. I tryed it but I get stuck on boot up and don't nothing but sit dere any ideas people I'm using jokers ics
    Sent from my MB855 using Xparent Green Tapatalk
    03-28-2012 03:53 PM
  2. FernBch's Avatar
    Did you flash only once? The process says to flash a second time
    I'm a MoPho-er
    03-28-2012 07:08 PM
  3. strawhatnito0890's Avatar
    Yup I did bro still stuck
    K.U.S.H 305 MB855
    03-30-2012 12:33 AM
  4. Bullfrog527's Avatar
    which recovery are you using? if you flashed it from ROM manager it won't work. you either need jokers recovery, which is on his site below the cm9 downloads, or the origional romracers 5.0.2.7 recovery.
    03-30-2012 02:26 PM
  5. strawhatnito0890's Avatar
    I have da right recovery it just not working idk Wats wrong
    K.U.S.H 305 MB855
    04-02-2012 11:41 AM
  6. Bullfrog527's Avatar
    did you flash twice? joker says that on a fresh install you need to flash twice then gapps
    04-03-2012 07:48 PM
  7. tirith's Avatar
    Try clearing data and cache, redownload and reflash.
    Swyped from my Photon using t-talk.
    04-03-2012 08:42 PM
  8. strawhatnito0890's Avatar
    Trust me I'm doing everything right
    K.U.S.H 305 MB855
    04-05-2012 02:15 AM
  9. tirith's Avatar
    Hence why I made my advice... If everything was right, it would bee working right...
    04-05-2012 05:48 PM
  10. mrDude's Avatar
    i am in the same scenario. try to clear data, partition, cache twice . Also using photon all wipe too. After reboot, it get stuck
    05-03-2012 12:25 PM
  11. Bullfrog527's Avatar
    did you flash twice? that helps, if it is really quick installing the first time, flash again and it will take longer and you will be good to go.
    05-27-2012 12:41 PM
