1. arcoms's Avatar
    Hey guys... deciding whether or not to root my Photon 4G. The thought of having to wait so long for ICS is driving me nuts and I figured I could flash CM9 on it. Which shouldn't be a problem. Except I am a total newbie and pretty much need step by step instructions cause I don't know anything about rooting and flashing roms. Any help would greatly be appreciated!
    beantown likes this.
    06-05-2012 12:54 AM
  2. beantown's Avatar
    I'm starting to have that same itch....
    06-23-2012 08:39 AM
  3. Bullfrog527's Avatar
    Check out qbking77 on YouTube. Has all kinds of great photon vids
    Sent from my MB855 using Android Central Forums
    06-24-2012 03:12 PM
  4. willistheyounger's Avatar
    Use this walk through it is a sticky on these forums
    http://forums.androidcentral.com/pho...t-hd-dock.html
    06-25-2012 11:40 AM
  5. beantown's Avatar
    thanks for the tip bullfrog...i'll make sure to check that out
    06-27-2012 07:23 PM
  6. XxNitr0xX's Avatar
    Not to hijack your thread, but I'm a first time rooter as well. I'm trying to figure out how to add clockworkmod. I used qbking's video to root, but I'm stumped with the CWM. Is it possible to flash ICS, etc without the clockworkmod??
    Thanks,guys.
    06-30-2012 06:28 PM
  7. Photon4glover's Avatar
    No it's not
    Sent from my MB855 using Tapatalk
    06-30-2012 08:43 PM
