Save big + get 3 months free! Sign up for ExpressVPN today
- Forum
- More Android Goodness
- The Archives
- Android Central Archives
- Motorola
- Sprint Photon
- Photon Rooting, ROM's, and Hacks
Restoring using Titanium Backup
- So my screen cracked big time over the weekend and I have a replacement being delivered tomorrow.
I have never had to do a restore, so I'm very nervous on how to bring everything over so it's all the same on the new device.
I'm rooted and using Titanium Backup, so I have hope that it will do what it's supposed to do, but are there any real-life experience lessons that anyone can share to help the full restore go smoothly?
Thanks in advance!07-09-2012 12:45 PMLike 0 - I suggest uninstalling Titanium Backup and ROM Manager as one of the two (prob Titanium Backup) messed up my Nexus S 4G. Backing up your phone and then restoring can always cause problems so i think you should just start fresh and copy the necessary things over...just my opinion07-20-2012 07:37 PMLike 0
- ZharaQueendroidI suggest uninstalling Titanium Backup and ROM Manager as one of the two (prob Titanium Backup) messed up my Nexus S 4G. Backing up your phone and then restoring can always cause problems so i think you should just start fresh and copy the necessary things over...just my opinion
Op, as long as you don't restore system data with TB, only user apps and data, it works great. I flash a lot, use it every time, and it's never let me down.tirith likes this.07-20-2012 10:18 PMLike 1
- Forum
- The Archives
- Motorola
- Sprint Photon
