1. randomosity117's Avatar
    So I have a rooted photon with 2.3.5. Is there any way to change how the status bar looks? It bugs me that all the icons are blue with a green battery :P
    Sent from my MB855 using Android Central Forums
    08-16-2012 11:17 PM
  2. tirith's Avatar
    Without being able to have a custom recovery, I don't believe so...
    Unless someone can walk you through terminal?
    Sent from my MB855 using Tapatalk 2
    08-17-2012 09:57 AM
  3. randomosity117's Avatar
    I found an app called rom toolbox pro. O can change all the icons without recovery
    08-18-2012 02:01 AM
  4. BenjaSands's Avatar
    Toolbox Pro? How complicated a process is it to change the icons...
    09-17-2012 03:04 PM
  5. tirith's Avatar
    It actually isn't too bad, I purchased it after seeing that reply... Smooth and easy
    09-26-2012 10:26 AM
