I have the 2 XL and was looking for a clear case without too much bulk and a lip to protect my screen a bit. I ended up ordering these 3 cases:
Power support air jacket
Spigen liquid crystal
Ringke fusion
I'll start with the easiest to share. The power support air jacket is a good case but it was not what I hoped it would be. It's firm and not very flexible (for better or for worse) and is a fingerprint magnet. Two biggest deal breakers - there is NO lip to help protect the screen and it is very slippery. If you are looking for a case that covers only the back and sides of your phone, is very sleek, and is clear, this is a good choice. However, it's also crazy expensive so you can likely find cheaper alternatives. Also, this case has button cutouts instead if a covering over the buttons. I thought I would like this but ultimately, I did not - it made it difficult to hit the buttons.
Spigen and Ringke - these two cases have more alike than they do in contrast. They are both TPU cases, are very flexible, and love fingerprints. They both fit very well around the phone and have a decent lip around the front to protect the screen. Now, the differences.
While I cannot say for sure (cuz I didn't measure it or anything, the Spigen seems negligibly thicker, and the cutout for the fingerprint scanner on the Spigen is a little exaggerated, in that it starts to curve very far outward and slopes gently toward the scanner. I, again, thought this would be great but I ended up not liking it's feel too much. The Ringke has a hard back and soft, flexible sides, which feels a little better in the hand. The Spigen has that "rubbery" feel all around, whereas the Ringke has the rubbery feel on the sides with a little more of a glossy feel on the back. I prefer this and do not think it compromises grip. Another difference is in the lip around the front screen. The Spigen lip remains the same size around all sides of the phone. The Ringke lip is largest at the corners, bottom, and top of the phone, and gets smaller around the sides. While it may be less protective, I found this to be a huge improvement over the Spigen because it made bringing the slider down from the top of the screen in landscape use much easier.
A final note, I have a Black 2 XL and got the Black Ringke (comes in 3 colors), whereas the Spigen only comes in one color (clear, glossy). If you have a Black Pixel, I think the black bezel really flows well with Black Pixel.
In conclusion, I really prefer the Ringke fusion over the other cases I bought (regardless of color). While there may be others out there, the Ringke is a great option for a clear case (with some color if you'd like) with limited bulk and a lip to protect your phone.
Hope this helps anyone that's looking!
Ringke fusion
