1. March1's Avatar
    Hey ya'll,
    I am looking for an adapter to simultaneously charge my phone and listen to my 3.5mm headphones, while I fall as asleep. I tried these but they didn't work:
    Type C to 3.5mm Audio Headphone Jack Adapter, Tontion 2 in 1 Nylon Braided Type C Charger and 3.5 mm Audio Headphone Jack Conversion Adapter.
    The ones on the google store, the Moshi USB-C to 3.5 mm Adapter/Charger for $44.95 are a bit steep. Anyone have an adapter that works that they recommend?
    01-31-2018 09:56 AM
  2. EvanKr's Avatar
    I ordered a cheapo eBay adapter a few weeks ago for about a dollar. No clue if it'll work but I'll let you know when it arrives!
    02-01-2018 04:38 PM
  3. March1's Avatar
    Awesome, please report back if you would.
    02-02-2018 09:19 AM
  4. FesterTreo's Avatar
    The cheapo adapters will never work because they do not include a DAC (digital audio converter) required for the headphones and power to run at the same time.
    02-07-2018 09:50 AM
  5. PaulQ's Avatar
    Have any of you found one of these charger/listen combos yet?
    04-05-2018 11:53 PM
  6. Mike Dee's Avatar
    Go to the Google store
    04-06-2018 07:58 PM
  7. PaulQ's Avatar
    I did. $45. Seemed like an Apple move. Usually you can find cheaper and equally effective versions on Amazon but, in this particular case, that may not be true.
    I might just plunk down the cash since my next trip is 29 hours. I don't want to use up the battery on my phone on the plane then be sitting in a Nairobi airport with no battery.
    Ugh... I just went to look and it says "coming soon." I have about 30 days so I'll hope it appears.
    04-06-2018 08:04 PM
  8. PaulQ's Avatar
    Correction of myself.... Just chatted with Google. It is just out of stock. I thought "Coming Soon" means it hasn't been offered yet.
    04-06-2018 08:13 PM
  9. Photo_Drew's Avatar
    resurrect this thread. I got one on Amazon for 15 bucks ish and it doesn't work. anyone found one besides google store?
    Adam Ziarnik likes this.
    05-29-2018 05:53 PM
  10. PaulQ's Avatar
    I thought I read recently that Google has decided not to sell theirs. I think it's been removed from their site. That tells me that there may be a problem with the whole concept.
    06-05-2018 12:34 AM
  11. GSDer's Avatar
    Hey here is the adapter you want: amzn.to/2twbLTB
    SoulSound usb c to 3.5mm with PD fast charging, $29.99 on amazon.
    Hi-Res DAC + PD
    Have you tested this yourself? Because in this recent article Jerry warns folks away from these devices. "Don't buy a USB-C adapter that lets you use headphones and charge at the same time" https://www.androidcentral.com/best-...oogles-pixel-2
    06-26-2018 03:31 PM
  1. Google Pixel 1 Mic Issue. Googles Not Doing Anything...
    By Android Central Question in forum Google Pixel & Pixel XL
    Last Post: 01-31-2018, 07:34 PM
  2. Keyboard Disappearing while using Facebook (Pixel 2 XL)
    By Android Central Question in forum Facebook
    Last Post: 01-31-2018, 10:44 AM
  3. What happen to my LG G2 D295 won' turn on and charge
    Last Post: 01-31-2018, 06:41 AM
  4. Keyboard Disappearing while using Facebook (Pixel 2 XL)
    Last Post: 01-31-2018, 06:01 AM
  5. Google Pixel 1 Mic Issue. Googles Not Doing Anything...
    Last Post: 01-31-2018, 05:28 AM
