1. hal1's Avatar
    Can anyone tell me the speed of the wireless stand vs the included quick charger?
    11-18-2018 12:03 AM
  2. chanchan05's Avatar
    The wireless will be slower if that's what you're asking.
    Laura Knotek likes this.
    11-18-2018 12:07 AM
  3. Yahya Syed's Avatar
    Wireless speed is slow
    11-26-2018 01:52 AM
  4. 18t's Avatar
    I wouldn't mind some stats on this also. Time to fully charge from 25% etc.
    11-27-2018 06:11 PM
  5. foxbat121's Avatar
    Wireless charge from the Pixel Stand is 10W while the official wall charger is 18W. 3rd party wireless charger will be limited to 5W. You should be able to use these numbers to extrapolate the charge time.
    Never bother to check the charge speed while on the stand because I only use the pixel stand when I go to bed. Really don't care about the charging speed
    Coop61 likes this.
    12-18-2018 07:18 AM
  6. jadejulius's Avatar
    You can't expect fast charging on wireless like wired charging, Google provides normal charging speed in wireless whereas in wired charger it has 18 Watts.
    02-13-2019 06:16 AM
  1. Replies: 2
    Last Post: 11-18-2018, 01:04 PM
  2. can´t acces to the web browser in my Hisense tv 32¨ h5 series
  3. How remove current version of android and install a clean version from google?
    Last Post: 11-18-2018, 03:21 AM
  4. How can I use the hotspot function on my unlocked (sprint) s8+?
    Last Post: 11-18-2018, 01:52 AM
  5. How to slow the expansionof the purple ooze on my screen
    Last Post: 11-17-2018, 11:10 PM
