1. drew munson's Avatar
    would an RCA 7" tablet with Google Android 5.0 (Lollipop) OS be able to run Pokemon Go?
    if so, can I set up a data plan for the tablet? what would be the cheapest plan per GB? I saw $15 data only cards at walmart that I believed would last a while given the small amount of data this game uses. I'd prefer to pay per GB and not per month.
    07-15-2016 01:14 AM
  2. drew munson's Avatar
    I have an ipod touch 6, will it work on there?
    07-15-2016 03:22 AM
  3. anon(632115)'s Avatar
    You need a device with mobile data enabled so that rules out the Ipod. There are numerous RCA 7 inch tablets so I don't now. If it has a sim slot, then it would likely support mobile data
    07-15-2016 05:17 AM
  4. drew munson's Avatar
    it's only $50 at walmart, but it's quad core. thanks though, I'll check for a sim slot.
    07-15-2016 07:15 AM
  5. anon(632115)'s Avatar
    Do you have a link for it?
    07-15-2016 07:58 AM
  6. drew munson's Avatar
    07-15-2016 09:36 AM
  7. drew munson's Avatar
    nvm, I see that there's no SIM slot....
    07-15-2016 10:21 AM
  8. anon(632115)'s Avatar
    Sorry I missed your earlier post. Yes, it's wifi only
    07-15-2016 10:28 AM
  9. drew munson's Avatar
    so what's the cheapest device with a sim card that I can buy? I just want to play pokemon go on it
    07-15-2016 10:36 AM
  10. Kjthomas0724's Avatar
    U can play with just wifi but you are very limited on where u can go. U have to be able to be on the WiFi the whole time u r playing
    07-15-2016 11:21 AM
  11. drew munson's Avatar
    yeah, but why not just play the gameboy versions then? I want to play pokemon go with prepaid data, no "plan." those things are a rip off, I've paid less than a quarter a day for talk/text and that's all I need.
    maybe I could get a smart phone that plays pokemon go and will allow me to transfer my minutes as well. does anyone know a smart phone that you can use the Tracphone prepaid crap with?
    07-15-2016 08:41 PM
  1. Blu Vivo Xl question
    By tonino2424 in forum Android Apps
    Last Post: 08-09-2016, 05:31 AM
  2. Android Wear Newbie - some (probably simple) questions
    By vaderag in forum Android Wear / Wear OS
    Last Post: 07-17-2016, 05:13 PM
  3. Question about USB debugging on Samsung Galaxy S6
    By mujibyepi in forum Samsung Galaxy S6
    Last Post: 07-15-2016, 12:52 AM
  4. Just got an SD card and have a question or two
    By iamloco724 in forum HTC 10
    Last Post: 07-14-2016, 08:44 PM
  5. Is this the forum for the G620S? If so, question about usb otg compatibility
    By rupert@heesom.org.uk in forum Huawei Ascend G6
    Last Post: 07-14-2016, 09:25 AM
