Store, what is the shield on the top right?
erwaso
2,652
18
Can someone explain the shield to me please?
It had a 1 inside of it and I clicked it and got coins. Then a timer of 21 hours started counting down. I think it has to do with defending a gym?
What gives?
AvaMichele
53
The way I understand it, as long as you are defending a gym, you receive coins every 24 hours, or less if you have pokemon in more than one gym.
kixfan
1,060
16
38
What gives?
If you defeat a gym for your team you can place one of your pokemon in the gym to defend it. Also if you see a gym already of your color you can check to see if it has an open space. If so you can also store a pokemon there to help defend the gym. If you do place pokemon into the gyms then you can go to the shop and collect rewards of pokecoins. The number in the shield shows you how many pokemon/gyms you have placed pokemon in. The more you place in the different gyms the bigger the reward is. You can only collect once a day though.
DaHui623
181
And I believe it stops at 10. So you can have more than 10 pokemon in different gyms but the gym trainer bonus, as it's called, caps at 10.
akbarramadhani12
