1. Zhock1's Avatar
    Hi.
    So.. my problem is. I have the xperia z3+ and when i try to download pokemon go, the game is not showing on the playstore, and from my pc google play says that my device is not compatible. There is anything i can do? Is a SO issue?
    Some friends can play the game from old xperia versions like z or z2... so idk.
    The device version is E6533
    Android 5.0.2
    The device is new, less than 3 hours since i bought it
    08-09-2016 02:16 PM
  2. SpookDroid's Avatar
    Unfortuantely device compatibility is up to the dev to set up. Maybe they found a device-specific bug, maybe the specific model is from a region that shouldn't have Pokemon Go yet, or maybe they just 'forgot' to add it.
    If your phone complies with the system requirements and is still showing as incompatible, shoot an e-mail to the dev as only they can change it. Your option, for now, is to 'sideload' the game, but remember, doing so MIGHT get your account banned from the game and there are so many 'tampered' APKs out there, so proceed at your own risk.
    08-09-2016 02:19 PM
  3. Zhock1's Avatar
    Well, problem solved aparently. i got a pop up for software update, dowloaded it and now all works fine.
    Thanks for the reply btw.
    08-09-2016 03:19 PM
  4. SpookDroid's Avatar
    Well there you go! haha Man, that was fast! :P
    Glad you got it working. Happy hunting!
    08-09-2016 03:54 PM
  1. S7 Active Camera Settings help
    By tkuhe in forum Samsung Galaxy S7 Active
    Last Post: 08-11-2016, 04:40 PM
  2. Battery Drain....help me :)
    By jelliebean82 in forum Samsung Galaxy S7 edge
    Last Post: 08-10-2016, 09:34 AM
  3. Motorola Ultra Max Droid is not charging
    Last Post: 08-09-2016, 02:22 PM
  4. Replies: 0
    Last Post: 08-09-2016, 01:23 PM
  5. Android Auto navigation does not work with my Galaxy S6
    Last Post: 08-09-2016, 12:54 PM
