1. Lucy Davies's Avatar
    I hatched a nice strong Bellsprout today with good IV's but should I power it up before evolving it or just evolve it then power it up? I never no which way round to do it. Also if I powered up a Pokemon then evolved it wouldn't it be a bit stronger coz it would have higher CP then?
    08-27-2016 03:58 PM
  2. fuzzylumpkin's Avatar
    In my opinion it's best to evolve first.
    As far as I'm aware, a Pokemon's CP will be the same no matter what, but the evolved forms gain far more CP per power up than non-evolved forms.
    08-27-2016 05:43 PM
  3. metllicamilitia's Avatar
    Generally you'll want want to wait until final evolution before powering up, as they evolve they get stronger anyway. So in this case you'll want to wait until Victrebell. You'll need 125 bellsprout candy to get there.
    08-27-2016 06:17 PM
  4. Lucy Davies's Avatar
    Thanks for the help. Can only evolve my Bellsprout once at the moment. Will just have to catch more.
    08-28-2016 06:16 AM
  5. wwwoodchuck's Avatar
    I would wait. I went to a park where Magikarp were very prolific, before the last spawn move. I evolved 6 and powered one up before evolving. Now, don’t hold me to these exact numbers, I did not write them down so just going from a faulty old memory here! When I powered up a Karp, it went up 3 CP and 1 HP. The Gyrados evolved at around 11.6 times the CP of the Karp. I was told it would be 12x but mine were close enough to use that as a rough estimate. Powering up a Gyrados, after the evolve would gain ~40+ CP and 1 HP. In ratio it gained a bit more CP by waiting, the HP increase was the same. The candy and stardust cost was the same for powering up right after the evolve. The iv was the same for both but after the evolve you don’t know what powers the Gyrados will have. If the evolved form doesn’t have the move set you liked, you would have to evolve another to see what it ended up with. It is nice to have two strong ones with different move sets also, to choose from for battling whatever is in a Gym.
    I have evolved quite a number of Pidgies and such (I call all the 12 & 25 candy common evolves my bread & butter for XP growth) but never checked to see if there was a relation to move sets before and after the evolve. Maybe someone else who did keep track will have an answer for that. It would be nice to know for higher level evolves like a Dratini to Dragonair to Dragonite though! With the Magikarp there is no telling, they all have the same strong moves before the evolve. <--- Poor attempt at humor.
    08-28-2016 07:52 AM
  6. Lucy Davies's Avatar
    Ok cool so I've done my Pokemon correctly by evolving them then powering them up. I don't really care about moves as that would be hard for me to have a high cp Pokemon, good IV's & a good move set.
    08-29-2016 05:58 AM
  7. Matty's Avatar
    it seems people all have different opinions, i always say power up first and then evolve. Get the half moon bar right to the bottom right and then evolve. Just my opinion.
    09-02-2016 03:08 AM
  8. dsip's Avatar
    Countering numbers with an opinion is not a particularly good argument.
    09-02-2016 05:10 AM
  9. fuzzylumpkin's Avatar
    This.
    09-02-2016 12:22 PM
  10. Morty2264's Avatar
    I've heard pros and cons for both.
    If you evolve first, you get that newly-evolved Pokemon into your Pokedex; and then you can simply catch a stronger CP Pokemon later.
    However, you can boost up your Pokemon and then evolve it; both of which would make them stronger. But then you will lose Stardust, and it's best to save up on that.
    I feel like it can be a gamble either way... There's always a chance that you'll run into a strong Pokemon in the wild; but still, evolving now versus waiting is a shorter-term solution and then your Pokedex is updated.
    I don't think there's really a "right" or "wrong" way - it's up to you! Friends have recommended both options to me; so I just do what I think is best at the time. :P
    09-02-2016 03:48 PM
  11. swish_08's Avatar
    i've always wondered which one should i do first, good thing i saw this. Thanks guys!
    09-05-2016 02:05 AM
  12. ZKnowN's Avatar
    Whatever you do just do it after lvl. 20
    projektorboy likes this.
    09-05-2016 07:50 AM
  13. person13628's Avatar
    evolve first
    09-05-2016 09:29 AM
  14. kixfan's Avatar
    I usually evolve first to get it added to my pokedex and worry about raising it's CP later. Usually I end up catching a stronger one first anyway. Seems like once I evolve a pokemon the first time I end up seeing it in the wild more often. Not sure if it is by design or if it just a coincidence though.
    09-06-2016 11:51 AM
  15. projektorboy's Avatar
    The rule is to always evolve first. Once evolved, you'll get more CP out of every power-up. No sense in wasting valuable Stardust by powering up something that could get transferred in favor of candy.
    As you level up you'll encounter stronger wild pokemon. One of those stronger wild pokemon may supersede a Pokemon you already planned to evolve for gyms. No point in burning Stardust because your natural progression will have you encountering a pokemon strong enough to have made the Stardust usage pointless.
    09-22-2016 03:37 PM
  16. swish_08's Avatar
    I just want to add an info about this, in the case of a magikarp, if you will consider moveset as well, better evolve it first before powering it up, if you want to have the best pokemon better consider IV and moveset.
    09-23-2016 02:05 AM
  17. Channan's Avatar
    It doesn't really matter based on CP alone. You'll get more CP by powering up a fully evolved Pokémon, but you'll get a much stronger Pokémon after evolving by powering up first. In the end, no matter if you power up before or after an evolution, the final evolution should have around, if not exactly, the same CP either way.
    And because of that, it's much better to power up AFTER evolving. The reason being because the moves your Pokémon knows after evolving is random. You don't want to waste your candies powering up a Pokémon first and then it gets a terrible move set after evolving. If you evolve a Pokémon and it has bad moves, save your candies and work on evolving another one.
    21stNow likes this.
    10-01-2016 08:37 AM
  18. swish_08's Avatar
    Yeah that's right, better be patient and save your candies and who knows, you might catch a better one than the one you're planning to power up and evolve.
    10-04-2016 02:40 AM
  19. fury2g's Avatar
    evolve first. Make sure you have the attacks and defenses you prefer and the powerup.
    10-08-2016 08:15 PM
  20. wwwoodchuck's Avatar
    While speaking of movesets I’ll add this. Movesets are completely random. Three times I have personally evolved the exact same Mon as two other people. Different levels one time and all over 30 for two evolves. We caught the same one and the appraisal said it was well over 80%, so we decided to see what happened. BTW, all have exactly the same iv’s no matter who captures it.
    In the case of a Magikarp: Different levels had different original CP and HP but evolved to a comparative CP and HP. Different movesets.
    Over level 30 (two on same level and team) catching the same Mon will have the same CP and HP: Polliwag and Charmander. First evolve was exactly the same CP, HP Length and weight; different attacks. Second evolve, same CP, HP, Length and Weight but different attacks.
    10-11-2016 07:50 PM
  21. JudgeDisco's Avatar
    Evolve First cause if you power it up before evolving you will have less power as if you were to power it up than evolve it and besides we all want that strong pokemon that will destroy anyone who comes in our way so wynaut enjoy the game and destroy any and all trainers who come in our way also with gyms never join gyms that are weak unless you are willing to power them up cause you will get your butt kicked unless its a strong gym your in
    10-14-2016 07:35 PM
  22. Lucy Davies's Avatar
    Thanks everyone I've been evolving my Pokemon then powering them up if I think they need it.
    10-14-2016 09:07 PM
  23. Z_Man_Horizons's Avatar
    dosent matter so long as their IV's are good.
    12-14-2016 02:12 PM
  1. Phone not capitalizing the first letter of every sentence?
    By Artistea in forum Samsung Galaxy S7
    Last Post: 08-28-2016, 12:05 PM
  2. Replies: 2
    Last Post: 08-28-2016, 07:15 AM
  3. Replies: 1
    Last Post: 08-27-2016, 02:08 PM
  4. Replies: 0
    Last Post: 08-27-2016, 01:02 PM
  5. Replies: 1
    Last Post: 08-27-2016, 12:21 PM
