1. swish_08's Avatar
    Hi, just want to ask when is Incense best used? While moving or stationary? I used one the other day and it didn't spawn any uncommon or rare pokemons and its as if I didn't use an incense since its only spawning very common pokemons. -_-
    09-26-2016 03:03 AM
  2. Lucy Davies's Avatar
    I heard it's best to use one while moving, I've done that & got loads of Pokemon. I've also heard that you can go deep into a field where you get no Pokemon on the sightings list & away from any roads/pavements & put one on & keep walking deeper into a field.
    09-26-2016 04:52 AM
  3. silver3drago's Avatar
    You'll probably encounter better Pokemon the higher level you are, and i'd say both moving/stationary might just get you the same yield. I've gotten plenty while sitting in one place.
    09-26-2016 10:02 AM
  4. fuzzylumpkin's Avatar
    If you're stationary you get about 1 Pokémon every 4 or 5 minutes, if you move you get 1 every minute or so apparently, providing you're moving fast enough for it to register.
    Either way you'll get the same common Pokémon with a very occasional rare if you're lucky. It's not worth spending money on in my opinion.
    09-26-2016 10:45 AM
  5. swish_08's Avatar
    i've read in another site that there's a trick in spawning uncommon or rare ones, they say that if you go in a secluded area away from roads, pokestops and gyms and you use incense, it will do the trick, how true is this?
    09-29-2016 02:19 AM
  6. Kxilev's Avatar
    Use them while moving, because you can find way more pokemon. Great to use if you are in an area that barely has any pokemon!
    10-09-2016 01:35 PM
  1. How do I cancel my Note 7 pre-Order (in India)?
    Last Post: 09-26-2016, 09:16 AM
  2. Replies: 2
    Last Post: 09-26-2016, 03:32 AM
  3. Update S4 Active To Android 6.0
    Last Post: 09-26-2016, 03:15 AM
  4. how to transfer galaxy S3 phone album photos to facebook
    Last Post: 09-26-2016, 02:49 AM
  5. how to transfer galaxy S3 phone album photos to facebook
    Last Post: 09-26-2016, 02:48 AM
