GPS Issue?
kixfan
1,060
16
38
I have been having a weird "glitch" the last 3 days. I will load the game and start playing. I notice that the character on the game will walk then stop for 5 seconds or so then run to catch up. It seems like the GPS is stuttering for some reason. Also when it's like this if I go into a gym to battle it will throw an error bar across the top and toss me from the gym. When I close the app and reload it to try fixing it I can't even get back into the app. It will stay on the loading screen and the bar at the bottom will get to around half loaded and just stall. At that point I have to just stop playing and try again later. Nothing I do at that point will get me back in. I cleared the app cache, cleared the app data, deleted and reinstalled the app, turned off location and turned it back on, rebooted the phone several times. Anyone else ever experienced this?? It makes me want to throw my phone when it happens! LOL. Anyone have any suggestions that may fix this?
smvim
1,080
53
48
In the event your GPS is the source of your problems, try installing this 'GPS Status & Toolbox' app:
https://forums.androidcentral.com/e...=com.eclipsim.gpsstatus2&hl=en&token=kRhipNRv
Start up the app and in its Menu there are three options you should run to see if this clears up your GPS functionality. There's 'Compass calibration', 'Calibrate pitch and roll', and 'Manage A-GPS state'. Do all three (especially the Manage A-GPS state) and hopefully this cleans out whatever might have been the problem.
kixfan
1,060
16
38
https://forums.androidcentral.com/e...=com.eclipsim.gpsstatus2&hl=en&token=TAtkfM6j
I'll definitely give that a try! Thanks for the help.
educationalco22
