1. daveligu's Avatar
    Hi everybody! Yesterday I published a new app in the Android Play Store, well actually its a Widget, the functionality is this: the widget scans for the Wifi connection state, so if it finds that the Wifi is turned ON but is not connected to any network, then the widget automatically turns OFF the Wifi, saving precious battery life!! It would be awesome if you could download it and test it. Any comments please let me know
    https://play.google.com/store/apps/d...attery.protect
    07-19-2012 04:13 PM
