1. ike2112's Avatar
    Looking for some help. I have a new LG G3, always had HTC previously and liked the sense widget.
    I'd like to have a homepage widget that shows time and weather, and ideally battery life as a number/percentage. I'd like it to be interactive - i.e. touch the time and I get taken to the alarm and clock functions, touch the forecast it opens the weather app etc. Also as the Lg G3 has 5 tiles across a screen, I'd like it to be 5 x 2 (most clock ones seem to be a max of 4) so it sits across the middle of the screen.
    I thought Id found the solution by paying for Zooper widget pro, then downloading the LG smart skin for it (search play store for LG G3 Zooper Widget Pro). But it doesn't seem to work - contrary to the explanation in the play store, it just gives the weather when you touch anywhere on the app, not the alarm etc.
    I guess using Zooper I could spend hours designing one, but I'd rather not as I'm sure there must be something already out there!
    PS. Was previously suggested Beautiful Widgets, but it also only goes as wide as 4 tiles, so I cant get it to sit in the middle of screen.
    10-07-2014 03:04 PM
  2. Gekko's Avatar
    10-07-2014 03:11 PM
  3. ike2112's Avatar
    Thanks for suggestion, however it doesnt extend to 5 tiles, only 4 so again its not in the middle of.the screen...
    10-08-2014 07:14 AM
  4. Gekko's Avatar
    try using Nova Launcher along with it in order to customize grid/display.
    Nova Launcher
    10-08-2014 08:16 AM
  5. apastrophe's Avatar
    Same case here. Had HTC for a long long time and switched to LG G3 few months back. I've been using "Android Weather" app widget. It's brilliant. Shows time, weather, battery and many more optional features
    11-12-2014 04:26 AM
  1. My email gets stuck in outbox on Android 4.4.4. Help?
    Last Post: 11-17-2014, 01:28 AM
  2. [HELP] My camera has a problem
    By hugorageX91 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 10-08-2014, 08:50 PM
  3. Replies: 2
    Last Post: 10-08-2014, 01:40 AM
  4. My LG G3 won't shut down. Can you help?
    By Mohammad Arshad in forum LG G3
    Last Post: 10-07-2014, 08:17 PM
  5. LG Optimus touchscreen not responding. What can I do?
    Last Post: 10-07-2014, 06:40 PM
