1. Onphonenumber2's Avatar
    Hi All,
    I was wondering if anyone knows who to fix a Galaxy S2 phone. I recently updated my software and some of my apps and the problems started.
    -Phone is freezing and I need to restart about every 1-2 hours
    -When restarting phone it will freeze with the 'Ok' Button highlight. I then need to take out the battery to restart.
    -Text messages are not coming through
    -Phone calls are not coming through, Ive called and it rings and rings then goes to voice mail and my phone does nothing.
    -My keyboard will pop up on screen but will not log any letters that i am touching.
    -Sometimes all i have on the screen is the backround. No apps no camera no nothing will show
    -and the screen loves to go black.
    I have gone thorugh and deleted some apps, I have also undid some updates to apps but the phone is still not working right. I called samsung and they told me to mail it in to them.
    Any options that i can try (Other than throwing it against the wall) will be greatly appreciated. Cause this is now the 2nd samsung that i have had that with in 6 months of purchusing started acting weird.
    04-02-2013 11:17 AM
  2. DroidXcon's Avatar
    Hi All,
    Have you simply tried backing up your data and doing a factory reset
    From my Galaxy Note 2 via Tapatalk
    04-02-2013 11:23 AM
  3. Onphonenumber2's Avatar
    No I have not. I am not sure how to back up my data....well pictures and videos. I have all my contacts saved to my gmail account so i have those its just the pictures i care about and dont want to loose.The 1800 number for samsung said that there is no way to remove the new updates. so im wondering if even setting it back to factory will work.
    04-02-2013 02:45 PM
  1. Help! My phone won't turn on...
    By iHateSprint in forum Samsung Replenish
    Last Post: 02-01-2014, 07:38 PM
  2. My phone is blazing now
    By HOLLYWOODANT215 in forum Samsung Galaxy S3
    Last Post: 01-21-2013, 02:09 PM
  3. Is it just my phone...
    By pinkcamaro17 in forum General Help and How To
    Last Post: 08-16-2012, 08:05 AM
  4. Help Needed for my phone
    By jgroves55 in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 08-10-2012, 01:43 PM
  5. I need help unbricking my phone
    By cusinndzl in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 08-10-2012, 09:57 AM
