Hello, I'm wondering if anybody has a solution to a problem that's been bugging me for a good while now...
I consistently download .zip files from the internet to get music on my phone. In order to get the music from the .zip file, you must extract it, a simple task that my phone does fine. When the extraction is finished, a new folder is created with the MP3 files in it. I recently bought an SD card to extend my phones memory, and have found in the past that moving files to it was an easy task. All I did was download the .zip file, extract it, then move both the .zip file and extraction folder to the external SD card at the same time. But now, all of a sudden, my phone cannot move these files. Midway through he process of moving the files to my SD card, my phone now says: There was an error while moving the files. No specific error is stated though. This is a long explanatuin, but I figured it would be to my benefit. If anyone could help me, it would be much appreciated. Thanks!
11-27-2013 12:49 AM
