Audio output when using Samsung DEX
RollingProtocol666
164
5
18
Hi, does anyone know that when you connect to DEX via a Monitor, how would I get Audio Output to come from the mobile instead of the monitor? I know the point of using DEX is that you can be independent from monitor when using the mobile... but in this case I would like to use MS Teams? Thx guys.
I believe it's a setting in the dex settings once you are in the dex desktop
Yes you can. I connected to my TV and got these options audio output TV or this phone.
BekaH
