1. AC Question's Avatar
    I have the new 2017 samsung galaxy a3 and have had it for about 4 weeks now, its the 16gb version and ive used 1.7gb on apps the phone tells me i only have 4gb left and that the rest is system data, how can the system data be 10gb+. I have brought a sd card and all my pictures are on it so i only have apps downloaded.
    03-30-2017 01:23 AM
  2. Blixy's Avatar
    I have the same problem!
    Also the phone is no longer able to write to my sd card. Not sure if this simply an issue with the sd card or not though.
    04-10-2017 02:43 AM
  3. tahterevalli's Avatar
    I strongly recomend you to contact with technical support..
    06-06-2017 09:18 AM
  1. Problems after factory reset
    By hishaq96 in forum Samsung Galaxy S7 edge
    Last Post: 02-26-2018, 10:43 PM
  2. How to Enable Adoptable Storage on S7 7.0?
    By Shujinko in forum Samsung Galaxy S7
    Last Post: 04-05-2017, 11:06 AM
  3. Problem staying connected to T-Mobile LTE
    By daggerman77 in forum Ask a Question
    Last Post: 04-01-2017, 11:32 PM
  4. Problems since update
    Last Post: 03-30-2017, 01:14 AM
  5. What Is /storage/emulated/0/dcim/photo editor?
    Last Post: 03-29-2017, 09:45 PM
