1. prawl's Avatar
    The 16gb sd card is full. I have bought a 64gb sd card and fitted and formatted it. Message says card full, so how do I bring the empty sd card into use
    12-23-2018 10:12 AM
  2. Rukbat's Avatar
    Everything that was set to save to the card is still set to save to the card.
    If you want what was on the old card to be on the new card, you'll have to copy it from the old card to the new one.
    12-23-2018 11:30 AM
  1. New Samsung galaxy s7 crashes - no fix?
    By Connor Leak in forum Samsung Galaxy S7
    Last Post: 12-24-2018, 11:10 PM
  2. What is credential storage used for
    Last Post: 12-23-2018, 03:52 AM
  3. Galaxy S6 925F Edge repair using doner phone parts
    Last Post: 12-22-2018, 11:00 PM
