1. pepsicokedr's Avatar
    Is anyone else experiencing this? Why is the screen takin up too much battery life? I already lowered the brightness, turned off smart stay and auto brightness and reduced screen timeout. I also disabled lots of apps I don't use (S voice, and lots of google apps) if that helps. This is my first android phone and I've only had this for 4 months and I haven't experienced massive battery drain when I was runnin on KitKat please help thank you!
    Attached Thumbnails Galaxy A5 battery drains fast after Lollipop upgrade-1441596027452.jpg   Galaxy A5 battery drains fast after Lollipop upgrade-1441596212129.jpg
    09-06-2015 10:26 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! The screen is the biggest energy user on a phone, so if you're using your phone a lot, it's normal for the screen to be responsible for the highest proportion of battery use. Judging from your screenshots, your screen is on track for total screen-on time of >5 hours, which is pretty good. In addition, your mobile signal looks pretty weak--if it's frequently weak, that can drain the battery, since it requires the cell radio to expend energy to boost the signal.
    pepsicokedr likes this.
    09-07-2015 02:20 AM
  3. Naxow's Avatar
    My girlfriend's A5 still uses kitkat, it's about 3 months old and the battery lasts long enough.
    I experienced only problems when upgrading my phone, from slower processing to battery drain, ask yourself if it's really worth it.
    Of course downgrading a phone is more complex and took me some time to acheive.
    09-13-2015 05:38 PM
  4. Edna Alcazar's Avatar
    I have a A-7 phone and my battery lasts 2 1/2 days while using games, hearing my playlists, and texting. Lollipop drains the battery way to much.
    09-22-2015 06:14 AM
  5. pepsicokedr's Avatar
    😢 I regret upgrading to Lollipop I really hope they fix this
    09-27-2015 07:52 AM
  6. Edna Alcazar's Avatar
    Sometimes newer is not better.
    09-29-2015 06:14 AM
  7. pepsicokedr's Avatar
    Yah I figured
    Irham Faozi likes this.
    03-23-2016 04:07 PM
  1. Replies: 3
    Last Post: 09-13-2015, 07:44 AM
  2. Why won't my Samsung Galaxy A3 find any networks?
    By Adrian Roke in forum Samsung Galaxy A3
    Last Post: 09-07-2015, 02:40 AM
  3. Replies: 1
    Last Post: 09-07-2015, 02:35 AM
  4. How do I exit car mode on a Samsung Galaxy S5?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 09-07-2015, 02:05 AM
  5. Replies: 1
    Last Post: 09-06-2015, 09:40 PM
