Hi,
My A5 was originally having 4.4.4 and the battery drain was not that severe earlier.
I upgraded to 5.0.2 and it started draining very fast. Even if there are no active APPs, it was draining 4 times faster when compared the previous software 4.4.4.
After reading some threads, which stated that downgrade back to 4.4.4. is a better solution, I downgraded the software to 4.4.4.
To my bad luck, it continues to drain very fast even after downgrade to 4.4.4.
When I looked into the battery usage, I see that Android System was consuming so much of battery.
Is there any good solution to get lesser battery drain (I am fine with any version of Android as long as the fast battery drain issue is resolved)?
Thanks & Regards,
Kannan
Thanks & Regards,
Kannan
