1. Tofan Fabio's Avatar
    I just restarted my phone after an.update and this icon appeared and won't dissapear after one more restart. I dunno what that is
    https://i.imgur.com/dbXKuKk_d.jpg?maxwidth=640&shape=thumb&fidelity=medium
    05-29-2018 01:35 PM
  2. SpookDroid's Avatar
    Do you have Wi-Fi Calling enabled or did the update add support for it?
    05-29-2018 02:26 PM
  3. Tofan Fabio's Avatar
    I didn't have it enabled. I tried that too. I had wi fi calling before the update
    05-29-2018 03:54 PM
  4. SpookDroid's Avatar
    If you put your phone into Airplane mode, does it go away? What about booting up into Safe Mode?
    05-29-2018 04:37 PM
  5. kbz1960's Avatar
    Speaker phone is on?
    SpookDroid likes this.
    05-29-2018 07:14 PM
  6. Tofan Fabio's Avatar
    With Airplane mode, yes, it goes away
    05-29-2018 11:19 PM
  7. Tofan Fabio's Avatar
    How can I see if is the speaker on if I'm not in a conversation
    05-29-2018 11:19 PM
  8. kbz1960's Avatar
    Good question. Just the closest I could find.
    05-30-2018 09:33 AM
  9. SpookDroid's Avatar
    OK, if with Airplane Mode it goes away then it is service-related. Try going into Airplane Mode and then turning WiFi back on. Does it appear again? If you boot your phone into Safe Mode, does it show up there? Do you have any BT headsets connected to the device (or wired ones)?
    05-30-2018 11:21 AM
  10. Javier P's Avatar
    Welcome to the forums. I remember a similar icon reported on some old threads. Where do you live? Is your carrier Orange Europe? I'll try to find those threads.
    05-30-2018 11:32 AM
  11. Javier P's Avatar
    05-30-2018 11:34 AM
  12. kbz1960's Avatar
    All I can find on that. Some app hanging or a background thing?
    05-30-2018 12:42 PM
  13. Tofan Fabio's Avatar
    I live in Romania and I saw that other people have tha same issue.
    06-01-2018 03:11 AM
  1. How to remove the com.android.system.v5?
    Last Post: 06-04-2018, 03:40 PM
  2. How do I get my Zenpad 3s10 screen to turn off automatically?
    Last Post: 06-04-2018, 03:39 PM
  3. trouble with my Alcatel tab
    By fatbob2345 in forum Ask a Question
    Last Post: 05-31-2018, 03:12 PM
  4. How to burn a video from your Galaxy S5 to DVD
    Last Post: 05-29-2018, 01:55 PM
