Hi, I'm running Android version 8.0.0 and just purchased a USB-C to RJ45 Gigabit Ethernet Adapter (https://www.ebay.com.au/itm/VOLANS-...247324?hash=item2ac061961c:g:YyIAAOSw53NY~eFZ). When connected & Ethernet enabled (in connection settings) I can run & update apps requiring an internet connection, but I'm unable to check or update the firmware ('Network not available. Try again later.') and the phone is not discoverable on the network (from Win 10 Pro 64 Bit).
Anyone with any clues or suggestions ? (please don't just recommend using wifi).
Thanks
Molly
Thanks
Molly
