1. Mike Zet's Avatar
    Hello everyone,
    I just discovered that my wife's Samsung Galaxy A50 with brand from Orange Poland is very strange phone and probably have something wrong.
    Found two issues with him:
    • After connect to car charger [key car is disconnected] it's power on radio and other devices in car,
    • Direct connect by good quality USB-C <--> USB-C don't work
    I also have a second A50, but without brand from mobile operator, and old A8-2018 and both those phones don't do this - don't power car electricity and are visible by PC on USB-C <--> USB-C connection.
    What I did so far - was:
    • factory reset
    • download last firmware from SamMobile for Orange and apply it
    • clean up USB-C port in device
    Unfortunately non of above don't fix issues.
    What is working on her phone:
    • Device is loading by ac adapter
    • Device is also discovered by PC when connect by USB --> USB-C cable
    I'm downloading from SamMobile image without brand - and will check it tommorow, but maybe someone from you was have those issues like this?
    I'm attaching picture with cleaned USB-C ports on both devices and videos what this behavior look like.
    Strange behavior after connect USBC cable or car charger on A50-20200213_185945_resize.jpg
    Cleaned USB-C ports
    In Car
    In home - connecting to PC
    02-13-2020 01:45 PM
  2. Rukbat's Avatar
    Pull down Notifications. At the bottom, you'll see he USB connection, and it probably says something like Zasil inne urządzenia. Tap that and change it to Przesyłanie plików / Android Auto
    Same thing - File transfer.
    02-13-2020 03:01 PM
  1. Ads on my phone even when not in an app
    Last Post: 02-14-2020, 07:43 AM
  2. Samsung A50 How to MOVE contacts to group folder?
    Last Post: 02-14-2020, 07:37 AM
  3. Double-Tap Wake/Sleep on Android 10
    By coffee-turtle in forum Android 10
    Last Post: 02-14-2020, 07:09 AM
  4. Replies: 2
    Last Post: 02-13-2020, 01:15 PM
  5. Double-Tap Wake/Sleep on Android 10
    By coffee-turtle in forum Android Apps
    Last Post: 02-13-2020, 12:29 PM
