so my phone shows the loading screen when u first turn on the phone but then the homescreen dosnt load it just shows a black screen! i can still hear notification sounds though and the back and menu buttons shine still!
Welcome to Android Central! Try the following procedure to get to the Recovery Menu, but instead of selecting "wipe data/factory reset," make sure to select "wipe cache partition." When it's done, select "reboot system now" and execute.
If that doesn't work, you may need to resort to a full factory reset.
