1. sarahwalker's Avatar
    So I have a Samsung Galaxy Ace 2 (which I've had for just over a year now) and I plugged in my phone to my laptop to see if I had an update for my phone because I've heard that loads of other people with similar Samsung phones have had some updates.
    So I went onto Samsung Kies and it says I have a firmware upgrade for my phone.
    I clicked the upgrade button and then a blank window comes up which shows what is on the window/tab behind it. I thought it had frozen originally and waited to see if it sorted itself out. 10 minutes later, still nothing. So I tried messing with it and just found that it's an empty window and it will close straight away.
    This image shows the window which has the Google homepage on it (that is what I had open as I had personal things open so changed it to that)
    I don't understand why it won't let me upgrade my phone and it has been bothering me for the last few weeks.
    Can someone please suggest anything to me?
    Thanks
    11-13-2013 07:23 AM
  2. Golfdriver97's Avatar
    Thanks
    Welcome to the forums. Is Kies up to date?
    From a Sprint Moto X using AC forums app
    11-13-2013 08:30 AM
  3. Smokey Mc Pot's Avatar
    Plan A
    Uninstall kies from your laptop completely.
    Than visit Samsung.com and download kies and install it again.
    That should do the trick.
    Plan B
    Follow this link instructions if you were unlucky again
    http://androidforums.com/showthread.php?p=5750102
    And it will work for shore!
    Sent from my GT-I8160 using Tapatalk
    11-13-2013 12:43 PM
  4. sarahwalker's Avatar
    Yes, Kies it up to date. I've uninstalled it a few times as well just incase and there still seems to be a problem.
    11-13-2013 03:41 PM
  5. Caitlyn D's Avatar
    Im having the same exact issue. Would LOVE some help!
    12-04-2013 06:29 PM
  1. Facebook notification sounds not working
    By Tomas Peitl in forum Legacy Android & Other OS's
    Last Post: 08-03-2015, 05:24 PM
  2. galaxy nexus on a reboot streak! plz help
    By Temorshah Ahmadi in forum Google / Samsung Galaxy Nexus
    Last Post: 12-13-2013, 07:09 AM
  3. Silverlight on S4
    By RamboJunior in forum T-Mobile Samsung Galaxy S4
    Last Post: 11-19-2013, 04:52 AM
  4. Video Highlights after update
    By Esskay54a in forum HTC One M7
    Last Post: 11-13-2013, 05:10 PM
  5. Replies: 2
    Last Post: 11-13-2013, 07:38 AM
