1. Torchi12's Avatar
    So I have 2 problems, I guess..
    1.
    Sometimes the screen will just turn black instantly. At first I thought it was the "do nothing for x seconds and it will go into hibernation" thing but if it was it would make the screen darker first and then after an additional y seconds go into hibernation. But sometimes it just instantly turns black.
    If I touch the screen nothing happends and if I press the home or power button the screen goes back to where I was (for example on a website in a browser) and not the lock screen (although I don't have a password or anything - it's just the 'drag your finger across the screen to unlock' thing).
    2.
    Sometimes I will be on my phone before going to sleep and I'll press the power button once to make it go into hibernation and when I wake up my phone will be dead - as if It wasn't in hibernation - but the screen was off/black.
    Sometimes it will do that, sometimes it wont and I don't understand why..
    02-24-2015 06:27 AM
  2. foxbat121's Avatar
    Welcome to the wonderful world of Android. While it gives you the great flexibility of doing anything possible, it also puts great responsibility on you to be careful what apps you install and use. On top of that, you have to deal with various bugs in the OEM ROM. But I suspect you have a rogue APP. Check the Usage app to see what drains your battery the most. Common trouble shooting tips are (1) clear your cache (2) factory reset.
    B. Diddy likes this.
    02-24-2015 10:58 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! I agree with foxbat121. In addition, make sure there isn't anything that generates a magnetic field near the phone--this might activate the phone's smartcover sensor, which turns the screen off and puts the phone to sleep.
    When you say the phone is sometimes dead in the morning, do you mean it has powered off on its own? Or that it ran out of battery?
    Steps to wipe the cache partition are here: HOW TO: Enter Recovery Mode on Samsung Galaxy Alpha - Complete Guide
    Also, try Safe Mode, which disables all 3rd party apps. If the problem goes away in Safe Mode, then you know it's an app you installed that's causing problems.
    02-24-2015 11:03 AM
  1. anyone with the QMV7A?
    By graygr in forum General Android Device Chat
    Last Post: 02-27-2015, 10:06 PM
  2. So Frustrated with HTC One (M8) Right Now
    By Manchild Prodigy in forum General News & Discussion
    Last Post: 02-25-2015, 01:23 AM
  3. Replies: 1
    Last Post: 02-24-2015, 11:19 AM
  4. Alarm problems
    By Begsby Wang in forum Samsung Galaxy S5
    Last Post: 02-24-2015, 03:04 AM
  5. Replies: 1
    Last Post: 02-23-2015, 11:58 PM
