1. Devbot's Avatar
    Hello!
    So a few months ago my Samsung Galaxy Alpha started to have some battery issues. It would drain really fast and turn off with 20% battery life. Then last week it died and wouldn't charge(completely unresponsive). I figured it was the battery so I ordered a new one (reputable) and it arrived today. I put it in and plugged it in and my phone came to life (was still off but showed it was charging) and said it was at 60%. The instructions said to let it charge for 5 hours so I left for work and when I came back it was at 1%. I turned it on and it was alive for maybe five minutes and then shut off and is now dead forever once again. What the heck is going on? I bought a new charger as well but it was just one from the gas station.
    06-08-2017 09:03 PM
  2. D13H4RD2L1V3's Avatar
    Hi there! Welcome to the forums.
    I'm a little skeptical on the gas station charger you got. It might not be the culprit but cheap chargers aren't exactly recommended for obvious safety reasons.
    Have you checked the phone itself to see if any services are eating up unnecessary resources?
    Golfdriver97 likes this.
    06-08-2017 09:39 PM
  3. Devbot's Avatar
    It can't be any apps/services because it's draining the battery while it's off. I will ask a friend to borrow their Samsung charger and see if that changes anything.
    06-09-2017 11:24 AM
  4. D13H4RD2L1V3's Avatar
    Android's kernel management has something called "wakelocks", which can drain the device's battery even when the device is asleep.
    If the phone is draining its battery while it's actually switched off entirely,then something is really wrong.
    06-09-2017 12:34 PM
  1. Looking at buying the new note 4 but can it mirror my whats app?
    By bigpaulgla in forum Samsung Galaxy Note 4
    Last Post: 06-09-2017, 04:54 PM
  2. Replies: 2
    Last Post: 06-08-2017, 11:07 PM
  3. Why is my messenger not working right
    Last Post: 06-08-2017, 10:53 PM
  4. My samsung galaxy 7edge is stuck on setup wizard
    Last Post: 06-08-2017, 10:52 PM
  5. Cannot find my apps on my phone
    Last Post: 06-08-2017, 08:33 PM
