My Galaxy Core 2: Battery is always at 0, switching off if I remove charging, same with new battery. What could the problem be?
A
AC Question
galaxy core 2: Battery always at 0%. switching off if i remove charging. same with new battery
Hi everybody...
Just recently i got changed my core 2 phone's display and touch as it was damaged.
now battery is always showing at 0% even charging continuously. phone is getting switched off if i remove the charging.
same thing happening even i change with new battery..
is this the android software problem or any hardware complaint.
Thanks & regards
Vedh
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,595
4,737
113
Re: galaxy core 2: Battery always at 0%. switching off if i remove charging. same with new battery
Welcome to Android Central! When you put in the new battery, did you let it charge on a wall outlet overnight, without disturbing it? Do that first. If the same thing happens, then something is probably wrong with a hardware component. Have you already tried a different charging cable/wall plug? If so, then it might be the microUSB port, or possibly the motherboard.
MarcosVo
