I have the Galaxy Z Fold 2. Getting a case which enables me to easily access my Edge Panels is impossible. With so much customization available for Android phones, is there a setting (or 3rd party app) which will make the Edge Panel wider (not longer vertically) horizontally? If there is, then accessing the Edge Panel would be not an issue. I know there are many of us with this new phone facing the same issue when we put on a case.
Does this case let you access the Edge Panel with ease? Or is it a struggle?
Thanks,
No problems with the Edge Panel and if they cut the same with Fold 2 you shouldn’t have problem either. Just due to the design as you can see it does not cover any of the screen cut perfectly at the edges. It’s basically a skin make of Kevlar instead of 3M it’s so thin. My problem was that it offered no space to provide a little barrier for accidental touches.
Note 20 Ultra. Too bad LaterCase doesn't have more pics of the Fold 2 case opened but being a Kevlar case, pretty sure it will be cut just as tight to the bezel as this one.
