Will the Galaxy Gear work with???
Raptor007
Trusted Member
Apr 18, 2010
4,906
58
Some users have posted it works but I don't know if the GG app is a d/l you can get or not and if so you could try. The downside is with out BT 4.0LE you risk battery drain and perhaps not a good trade off. From what I can tell S4 4.3 should be very soon as in November, S3 and N2 will be December(ish) time frame or longer.
ulrichs
Currently Galaxy Gear does NOT work fully with G4S. You can NOT install any additional apps, and the weather and other info is not sent automatically.
Also, you constantly have to reconnect bluetooth and it only can support 1 bluetooth combination at once.
Samsung promises releases of 4.3 with gear update.
