1. CehowardNote7's Avatar
    Will the Galaxy Gear work with these Samsung Galaxy phones?
    S3
    S2
    Note 2
    I know it works with the Samsung Galaxy S4, 80%
    10-18-2013 02:47 PM
  2. Kloge Aage's Avatar
    S3
    S2
    Note 2
    Update 4.3 = S3, S4 & Note 2
    10-18-2013 03:51 PM
  3. CehowardNote7's Avatar
    Thanks for that feedback..
    But, even with the 4.2 or what the Note 3 comes with, the Gear will work with the S4, am I correct, not all things working but calls and most major things work with 4.2.. ??
    bkprunty likes this.
    10-18-2013 05:35 PM
  4. Raptor007's Avatar
    Some users have posted it works but I don't know if the GG app is a d/l you can get or not and if so you could try. The downside is with out BT 4.0LE you risk battery drain and perhaps not a good trade off. From what I can tell S4 4.3 should be very soon as in November, S3 and N2 will be December(ish) time frame or longer.
    10-18-2013 10:01 PM
  5. ulrichs's Avatar
    Currently Galaxy Gear does NOT work fully with G4S. You can NOT install any additional apps, and the weather and other info is not sent automatically.
    Also, you constantly have to reconnect bluetooth and it only can support 1 bluetooth combination at once.
    Samsung promises releases of 4.3 with gear update.
    10-19-2013 01:15 AM
  1. Push Push 4.3: The Countdown Begins
    By ectoren in forum T-Mobile HTC One
    Last Post: 10-21-2013, 10:06 AM
  2. Caller ID Annoucement Galaxy Note Verizon
    By Word2YaMamma in forum Verizon Samsung Galaxy Note 3
    Last Post: 10-19-2013, 10:24 PM
  3. Retrieving contact icon from the bin
    By Rita Ray in forum General Help and How To
    Last Post: 10-19-2013, 11:02 AM
  4. Droid X2 with 2.3.5 custom notification sounds
    By metllicamilitia in forum Legacy Android & Other OS's
    Last Post: 10-19-2013, 09:20 AM
  5. GS3 will not connect to PC sgh_t999
    By dylanwelch95 in forum T-Mobile Galaxy S III
    Last Post: 10-18-2013, 02:42 PM
