1. DAS's Avatar
    Has anyone connected the GG to their 10.1 2014 edition?
    Sent from my SM-P600 using AC Forums mobile app
    10-19-2013 10:59 PM
  2. RBChamp's Avatar
    I haven't tried. Though I have both as I am rather sure you do from following these forums. Have you tried and had issues?
    Sent from my SGN 10.1 2014 Edition Using Ac forums mobile app .
    10-20-2013 03:06 PM
  3. dlg_az#CB's Avatar
    I tried, without success. Reason being, I think, is on the Gear's settings for bluetooth ... the Visibility setting is grayed out for now. However, I unchecked Bluetooth, waited a moment and checked it again, then the Visibility became active. If you check it quickly you can see it will be visible for 2:00 seconds then it quickly goes inactive before you can get a scan done on the Note 10.1.
    10-20-2013 07:41 PM
  4. davem2421's Avatar
    does the 10.1 2014 edition have NFC? would you pair it the same way as the N3 by touching the charging dock to the tablet?
    10-21-2013 02:36 PM
  5. dlg_az#CB's Avatar
    No NFC on the 2014 edition. That would have been the first thing I'd have tried, if so.
    10-21-2013 05:05 PM
  6. davem2421's Avatar
    I didn't know if it was different or not. odd they didn't include NFC.
    10-22-2013 05:42 AM
  7. dlg_az#CB's Avatar
    I think NFC is intended mainly for phones so you can tap with another to transfer data. Its the tapping function that makes it work, I believe. I guess the mfg'ers couldn't see folks tapping their tablets together to transfer data.
    10-22-2013 07:34 PM
  8. 21stNow's Avatar
    I think that the NFC action between the Gear and the phone is just to launch the Samsung App store to download the Gear Manager app. You can do this manually. The actual pairing of the Gear to the device is done via Bluetooth.
    10-23-2013 11:15 AM
  9. dlg_az#CB's Avatar
    I haven't seen the Gear app in Play Store so I don't think you can download it manually. I'm aware the connection is blue tooth but having the Gear Manager on the tablet would be great.
    10-23-2013 07:03 PM
  10. 21stNow's Avatar
    The Gear Manager app is not in the Play Store. It is in the Samsung App store.
    10-23-2013 08:29 PM
  11. dlg_az#CB's Avatar
    Well, color me dense.
    10-23-2013 08:33 PM
  12. dlg_az#CB's Avatar
    Apparently you can't download the Gear Mgr app from the Samsung App store using a tablet. It doesn't show up on a search.
    10-24-2013 11:44 AM
  13. DAS's Avatar
    I am sure connecting the two devices is possible, but I still have not figured out how
    Sent from my GT-N5110 using AC Forums mobile app
    10-31-2013 09:41 PM
  14. adeeb saban's Avatar
    Hi,
    Did anyone ever manage to connect these 2 devices?
    07-12-2014 09:13 AM
  15. bryevs's Avatar
    My gear s connected to my p605 tablet for about 3 weeks when i spoke to samsung they said that the tablets have something in the software to stop them connecting to gear watches,only for mobile phones to connect,an update from samsung dissconnected my tablet
    01-09-2015 06:11 AM
  16. honda-Dave's Avatar
    Hmm, I have my gear 1 connected to my tab pro 8.4, it should work?
    Galaxy Note 4
    Galaxy Tab Pro 8.4
    Galaxy Tab 2
    Galaxy Gear S/ Gear 1 Tizen
    Galaxy Circle/ Gear Level speaker
    01-11-2015 06:24 PM
  17. karem elhindy's Avatar
    are you talking seriously??? samsung did that on purpose??
    i hv note 10.1 p605 and i cant connect it with gear s r750, the gear manager keep telling me that my device aint support the gear.
    is that what happened with u?
    06-30-2015 05:35 PM
  18. pduffer's Avatar
    Just a question - do you always have your tablet with you?
    Sent from my SM-P900 using Tapatalk
    08-02-2015 08:31 PM
  19. juiceup's Avatar
    currently have the P600 linked with the Gear S SM-R750. automatically downloaded the Gear App after bluetooth link. but Gear App Store doesn't load and so is downloading additional clock faces. any solution?
    12-11-2015 04:48 PM
  1. I'm a little overwhelmed here, what are some good tips and tricks to do?
    By smalba in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 10-28-2013, 08:35 AM
  2. How to get Roam Only network option on Sprint Photon?
    By Atanasoff1 in forum Sprint Photon
    Last Post: 10-23-2013, 04:31 PM
  3. How to stop the browser address bar from hiding?
    By kwitel in forum HTC One M7
    Last Post: 10-21-2013, 09:32 PM
  4. Replies: 6
    Last Post: 10-20-2013, 03:47 PM
  5. How to tether my Nexus 7 to my laptop or connect to its ad hoc wifi
    By topshot45 in forum Google Nexus 7 Tablet (2012)
    Last Post: 10-20-2013, 06:35 AM
