1. rockrchic923's Avatar
    So I am considering purchasing a galaxy gear and I just wonder if someone who has one could tell me what apps are available for it. I've scoured the Web looking for a list and haven't been able to see one.
    Thanks!
    Sent from my Note 3 using AC Forums mobile app
    11-24-2013 04:31 AM
  2. rajnet's Avatar
    You can only see the app store if you click on galaxy gear app while connected.
    11-24-2013 12:24 PM
  3. Fatasaurus's Avatar
    There aren't many. Some news watch faces, there's some social ones and some note taking ones. That's about it.
    Sent from my SM-N900T using Tapatalk
    11-24-2013 03:47 PM
  4. rockrchic923's Avatar
    The app I am really wanting is Google play support. I use that almost exclusively since I switched from iPhone and would love to be able to control what songs are playing from the gear. If that works then I'm pretty sure I'm going to make the leap.
    Sent from my SM-N900V using AC Forums mobile app
    11-24-2013 04:35 PM
  5. rajnet's Avatar
    Nope that is not available yet.
    11-24-2013 04:46 PM
  6. rockrchic923's Avatar
    Hopefully soon, because that would definitely sway my decision.
    11-24-2013 09:35 PM
  7. UsedName's Avatar
    The GG is to new for developers to roll out apps for it.... you'll (we're) have to be patient for now.
    11-24-2013 10:18 PM
  8. karsdroid's Avatar
    check out the xda forum. if you are willing to use a rom they've got some great stuff going there....bluetooth tethering....hooray.
    11-24-2013 11:02 PM
  9. Fatasaurus's Avatar
    That's not true!! The media controller is the same one that shows up on your lock screen and in your notification bar. ANY music source that's playing on your phone you will be able to stop start and skip with the Gear.
    mrwallyy likes this.
    11-25-2013 01:16 AM
  1. AT&T Galaxy S3 - Dashclock widget with PIN lock???
    By KreepyKen in forum AT&T Galaxy S III
    Last Post: 01-06-2014, 09:20 PM
  2. galaxy s2 battery drains quite quickly
    By theodorepm in forum Samsung Galaxy S II
    Last Post: 11-29-2013, 12:40 PM
  3. Replies: 7
    Last Post: 11-25-2013, 10:49 AM
  4. Google Nexus 5 data transferring problem!!! HELP
    By Yasser Almalky in forum Google Nexus 5
    Last Post: 11-24-2013, 07:07 PM
  5. Help cyanogenmod for s4
    By jlcbourne in forum Samsung Galaxy S4
    Last Post: 11-24-2013, 10:17 AM
