1. thegame161's Avatar
    As i'm guessing to find your device it has to use a certain amount of battery life, right?
    11-27-2013 04:57 PM
  2. karsdroid's Avatar
    I don't see a drain at all....i have had my gear on since 7am...its now after 3pm and i've had about 5 phone calls on it, and the usual notifications, etc and my phone is at 74%....
    11-27-2013 05:18 PM
  3. thegame161's Avatar
    interesting, how do you sync it does it just find your note when both are switched on?
    11-27-2013 05:19 PM
  4. karsdroid's Avatar
    the gear connects to your phone via bluetooth just like a headset....
    11-27-2013 05:30 PM
  5. thegame161's Avatar
    Ah see you need bluetooth on? right ok thanks
    11-27-2013 05:32 PM
  6. karsdroid's Avatar
    honestly, i just leave the bluetooth on all of the time now...if you walk away from the phone far enough the gear disconnects from the phone and then reconnects when you get closer. it's not something you have to manage or even think about and like i say, i don't see any real drain on my battery.
    11-27-2013 05:35 PM
  7. thegame161's Avatar
    so you don't think bluetooth affects battery life for you then?
    11-27-2013 05:45 PM
  8. UsedName's Avatar
    Naw, bluetooth use very little battery...if not all.
    11-27-2013 07:51 PM
  9. karsdroid's Avatar
    nope, not at all!!
    11-27-2013 10:19 PM
  10. CehowardNote7's Avatar
    The battery on the Note 3 is the CHIT!! I don't think it will ever run out!! .. But, if it does, I got a spare to snap in and I will be back to 100% in less than 30 seconds..
    11-28-2013 04:39 PM
  11. mrwallyy's Avatar
    Doesn't affect it much.
    11-30-2013 04:34 AM
  12. rajnet's Avatar
    Yes so don't effect much at all same here.
    11-30-2013 06:11 AM
  13. waynew73's Avatar
    Not to mention that the devices now use low energy blue tooth, so no more of the drain we used to see.
    Sent from my Nexus 7 using Tapatalk
    12-01-2013 08:46 PM
  14. 21stNow's Avatar
    I couldn't tell you the difference in battery life. I only used the Note 3 for three days before I got the Gear, and the Gear has been paired ever since. I'm one that has always left Bluetooth on on my main phones for the last three years, so I don't even know what battery life is like if Bluetooth is off.
    12-01-2013 09:04 PM
  15. Stuker442's Avatar
    I've had my Gear for a few days and it doesn't affect battery life on my Note 3 at all. This low power Bluetooth 4.0 seems to deliver what it promises.
    12-02-2013 11:03 AM
  1. Replies: 1
    Last Post: 11-29-2013, 11:05 PM
  2. Replies: 5
    Last Post: 11-27-2013, 07:48 PM
  3. KitKat Plus and Minus -- Your Experiences?
    By gerryp123 in forum Google Nexus 7 Tablet (2013)
    Last Post: 11-27-2013, 04:47 PM
  4. Any word on 4.4 KitKat for Rogers Moto X?
    By JFish92 in forum Moto X
    Last Post: 11-27-2013, 04:16 PM
  5. How do I sync app folder organization to a new phone or tablet
    By raiderhoops2206 in forum General Help and How To
    Last Post: 11-27-2013, 04:14 PM
