Still have not gotten either the gear manager update or firmware update here in Delaware. Anyone on the east coast get it yet?
Time to just flash the UK version and move on. On a side note, I know I am missing something but where the heck is the Samsung App's "App" on the Verizon Galaxy Note 3? Its not there and I have checked the device, short of hard reset why isn't it there?
Samsung should really be more concerned about the US owners of this device.
All 7 of us.
Does anyone have a link to the step by step how to load the UK version on the current Galaxy Gear for updated firmware?
That did it, and it was Easy Thank you guys.I used this to update mine: Official update to Gear Nov 15th and more *notifications*! - Page 12 - xda-developers
EDIT: This post has links to the files that will download faster Official update to Gear Nov 15th and more *notifications*! - Page 16 - xda-developers
Let me know if you have any questions!
The U.S is now two updates behind. Just download MK7 from Samsung-Updates or the firmware list on the front page. It's a 280MB files so it only takes 20 minutes to download. Use any version of Odin to install it. Put the Gear in download mode by long pressing the power button until it says "rebooting" and then press it again a couple of times until the download menu comes up. Select "download mode" by pressing the button to highlight it. Long press the button to select it. With the Gear in download mode, connect it to your PC and open Odin. Take the .MD5 file you extracted from the downloaded MK7 .zip and put it in "PDA" in Odin and then click start. You should be done in about 5 minutes and your Gear will restart. When it does, unplug it from the USB cable. There's no downside to using another region's f/w on your Gear and the update process doesn't wipe your Gear's data or settings. I don't think Gear's are different h/w wise regionally so you can repeat the above process when an update gets pushed, even if it's for another region, to always keep your Gear on the latest f/w.
In addition to the notification stuff, Samsung's added the ability to "go to the last page" under "Motion" so when you bring your wrist up it returns to what you're doing rather than defaulting to the home page (clock). You can also customize the S Reply messages you can send when you're on a call or responding to a text.
The Gear feels snappier after the update.
The way I see it is let them release update out of country first. Suppose they released an update that messed up everything. Let someone else be the ginny pigs. Just think,, when it's released here any day now atleast we know there are no issues with it.
THE BEAST,,NOTE 3. SIZE IS EVERYTHING!!!
